Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Objects and the XSD Wizard > Structure of XSD XML Integration Object > XSD Specific Integration Component Field User PropertiesTable 14 lists integration component field user properties for representing XSD as an XML integration component. |
XML Reference: Siebel eBusiness Application Integration Volume V |
