Siebel Field Service Guide > Engines Logging Levels > Business Service Engines for Siebel Field Service > Logging LevelsEach engine has an associated logging level. A logging level is a level of detail for automatic event logging when a Siebel application component is running. The logging level is expressed as a number, with higher numbers representing greater levels of detail. Table 136 shows the logging levels and their definitions. The default logging level for each of the engines is 1. If you need more detail in testing or troubleshooting, you can specify a higher logging level for the engine. You can modify the logging level by using one of the following methods:
For more information about configuring business services, see the chapter on business services in Integration Platform Technologies: Siebel Enterprise Application Integration. |
| Siebel Field Service Guide |
