Generally, a business service has the following characteristics:
Defines reusable business logic that can be executed within the Object Manager
Can be a built-in service that is defined in Siebel Tools or a run-time service that is defined in the Siebel client application by administrators
Can be based on the CSSService Class (standard business service) or on specialized classes (specialized business service)
NOTE: Specialized business services are used only by internal Siebel Engineering personnel. Customers should not use specialized business services unless their behavior is specifically documented.
Can be configured by properties or scripts (written in Siebel VB or Siebel eScript)
Can be called by a workflow, a script, or directly from runtime events
Can be used for generic code libraries that are called from other scripts
Are used as building blocks in the Siebel Application Integration framework
Can be referred to by commands associated with a menu item or toolbar button
