Siebel Field Service Guide > Business Service Methods Reference for Field Service > Agreements > GenerateNRCCharge MethodGenerateNRCCharge is used to generate the nonrecurring charge (NRC) for an agreement line item. UsageThis method is called by the FS - Generate NRC Charge workflow. Once the NRC is generated, the process also updates the NRC last-charged date on the charge plan. Additional DetailsThe input date for this process should be in the local time format, which the process converts to Open Database Connectivity (ODBC) format (YY-MM-DD). |
| Siebel Field Service Guide |
