Siebel Field Service Guide > Business Service Methods Reference for Field Service > Agreements > GenerateRCCharge MethodGenerateRCCharge is used to generate the RC amounts for an agreement line item. UsageThis method is called by the FS - Generate RC Charge workflow. The workflow retrieves and converts the asset readings to charge amounts. Once the RC amount is generated, the process also updates the RC last-charged date on the charge plan. Additional DetailsThe input date for this process should be in the local time format, which the process converts to the ODBC format (YY-MM-DD). |
| Siebel Field Service Guide |
