Siebel Field Service Guide > Business Service Methods Reference for Field Service > Agreements > GenerateUsageCharge MethodGenerateUsageCharge is used to generate the usage charge for an agreement line item based on asset usage. UsageThis method is called by the FS - Generate Usage Charge workflow. The workflow retrieves and converts the asset readings to charge amounts. Once the usage charge is generated, the process also updates the usage last-charged date on the charge plan. Additional DetailsThe input date for this process should be in the local time format, which the process converts to ODBC format (YY-MM-DD). |
| Siebel Field Service Guide |
