Siebel Field Service Guide > Business Service Methods Reference for Field Service > Preventive Maintenance > GeneratePM MethodGeneratePM generates service requests and activities for the maintenance of assets, based on predefined triggers. UsageThe following input arguments are required for this method: Depending on the combination of the Mode and Sub-mode values, the other inputs can be specified. For example, if the value for Mode is SQL and the Sub-mode value is Assets&Plans, then the Plan SQL and Asset SQL arguments must be specified. DefOrgID and DefActOwnerId denote the default organization for the service requests or activities created and the owner for the activities. The input parameters are called if invoking from code or from a component request. See Parameters for the Preventive Maintenance Engine for more information about the parameters used with this engine. Additional Details |
| Siebel Field Service Guide |
