Siebel Field Service Guide > Business Service Methods Reference for Field Service > Scheduling > ReloadServiceRegion MethodReloadServiceRegion loads or reloads service region data into the ABS cache. This method should be called if the parameter sets or the schedule changes for a service region. It is also used to change the ABS time horizon for a service region. UsageThis method is called when the user clicks the Load ABS button on the Administration - Scheduling screen > Service Region List view. It is typically invoked from a repeating component request that refreshes the service regions time horizon. Additional DetailsThe inputs for this method are described in Table 151. |
| Siebel Field Service Guide |
