Siebel Field Service Guide > Cycle Counting and Replenishment > Replenishment Engine >
System Preferences for the Replenishment Engine
The Field Service engines have system preferences, listed in Table 99, that determine the behavior of each engine. These system preferences are stored in the table S_SYS_PREF. The BusComp is System Preferences. These are the columns of main interest:
- SYS_PREF_CD. Name of the system preference.
- VAL. Value of the system preference.
Table 99. System Preferences for the Replenishment Engine
InvLocTypeForReplenishRelation |
Warehouse |
Specifies the default replenishment level. Orders to replenish any level of an inventory location have this value as their Destination. |
ReplenishOrderPriority |
Medium |
Specifies the default order priority for newly created orders. The values should be from the Order Priority LOV and individual values should be LIVs. |
OrderItemStatusForOnOrderQty |
Open, New, Pending |
Specifies the valid values for the existing order item status. The values should be from the Order Item Status LOV and individual values should be LIVs. |
OrderStatusForOnOrderQty |
Specifies the valid values for the existing order status. The values should be from the Order Status LOV and individual values should be LIVs. |
OrderTypeForOnOrderQty |
Internal Order, Purchase Order |
Specifies the valid values for the existing order type. The values should be from the Order Type LOV and individual values should be LIVs. |
The last three parameters specify what kind of orders, order items, and order types to look for when searching for an existing order, to avoid creating duplicate orders. CAUTION: The Order Status List of Values should have Open as its Language Independent Value. If it does not, the Replenishment Engine will not work.
NOTE: To register changes to System Preferences, restart the Field Service server.
