Table 100.	Parameters for the Replenishment Engine
    InvokeMode  |
    Id  |
    In this mode, specify the inventory location to be replenished and the engine will replenish the specified location.  |
    SQL  |
    In this mode, specify the WHERE clause, meaning specify some criteria and replenish the inventory locations which meet that criteria.  |
    TEMP  |
    In this mode, put all the required parameters into a temporary table with a particular Client Request ID and pass that ID to the server to retrieve the parameters from Temp Table.  |
    ClientId  |
    A row ID for retrieving parameters from the temp table  |
    Required when InvokeMode = TEMP.  |
    SourceType  |
    I (Inventory Location)  V (Vendor)  |
    Required when InvokeMode = TEMP. Defaults to I when InvokeMode = Id or SQL.  |
    DestId  |
    Destination Inventory ID  |
    Required when InvokeMode = Id.  |
    WhereClause  |
    SQL Where Clause  |
    Business Component Search Spec. Required when InvokeMode = SQL.  |
