Siebel Field Service Guide > Preventive Maintenance > Preventive Maintenance Screen > Triggers ViewThe Triggers view provides four subviews (Time Interval, Month-Day, Usage, Threshold, or Event) to define the triggers that activate PM plans. Time Interval SubviewThe Time Interval subview sets the interval in days between triggers that activate a selected plan. A plan can have more than one Time Interval trigger. For more information, see Time Interval Triggers. Table 124 describes items in Time Interval records. NOTE: The age of the asset is measured from the Install Date. If the Install Date is missing, the asset is considered to be 0 days old. For more information, see the Assets View. Usage SubviewThe Usage subview defines the measurement and measurement parameters that trigger a PM plan. A plan can have more than one Usage trigger. For more information, see Usage Triggers. Table 125 describes items in Usage records. NOTE: For Time Interval and Usage triggers (which use Valid Start and Valid End settings), if the interval falls beyond the Valid End, the trigger does not fire. Threshold SubviewThe Threshold subview defines a reading from an asset that triggers a PM plan. A plan can have more than one Threshold trigger. For more information, see Threshold Triggers. Table 126 describes the item in Threshold records. Event SubviewThe Event subview defines the number of service requests in a time interval that trigger a PM plan. A plan can have only one Event trigger. For more information, see Event Triggers. Table 127 describes items in the Event subview. Both items are required.
| Siebel Field Service Guide |
