Fundamentals > About Records, Fields, and Field Controls > About Option ButtonsOption buttons, also referred to as radio buttons, allow you to choose one of several options in a set. An option button appears as a circle, with a smaller, filled circle inside it when the option is selected. You cannot choose more than one option button in a set. Figure 28 shows an example of option buttons. |
Fundamentals |
