Fundamentals > About the User Interface > About Charts in the User InterfaceSometimes data can be displayed in chart format. Charts are graphical representations of data and are available as views in some screens. Charts are used to compare data sets. Typically, you can access the chart by clicking the Charts hyperlink in the link bar below the screen tabs. An example of a chart is shown in Figure 20. Use the drop-down list in the chart's title bar to determine which data is represented in the chart. This allows you to toggle between data sets. Most charts also include a drop-down list of chart types from which you can select the type of chart you want to see, for example a bar chart rather than a pie chart. Saving ChartsYou can save the charts in your Siebel application for use in other applications, for example, Microsoft PowerPoint. |
| Fundamentals |
