Fundamentals > About the User Interface >
About Common Buttons in Lists and Forms in the User Interface
The buttons described in Table 6 appear at the top of lists and forms. In addition to these buttons, your Siebel application may contain additional buttons or other elements on each list and form.
Table 6. Common Buttons in Lists and Forms
Button
Description
Menu
The menu button provides access to a menu of actions that apply to the active form, list, or explorer view, or a selected record in a list. Using the options in the menu, you can perform actions such as copy, edit, delete, and advanced sorting.
NOTE:  If you right-click in a form or a list you can access the same menu of actions provided by the menu button in that form or list.
New
Lets you create a new record. In a list, clicking this button inserts a new, empty row at the top of the list so you can create a new record. In a form, clicking this button displays a form with empty fields that you can fill in to create a new record.
Delete
Lets you delete the selected record.
Query
Lets you define and launch a query in a form or list. For more information about querying, see Using Query to Locate Information.
Fundamentals
