Fundamentals > Getting Started with Your Siebel Application >
Using the Inbox
The Inbox provides you with a centralized list of items requiring your attention, such as approvals and notifications. The Inbox can include almost any business entity, including service requests, approvals, and opportunities. When you highlight an item in your Inbox list, the Detail view in the lower part of the application window is updated to show the fields for that type of business entity. This allows you to see the details of the record without having to navigate to another screen. You can also perform default actions, such as approving an expense report, directly from the Inbox. To check your Inbox
- From the application-level menu, choose Navigate > Site Map.
- Click Inbox.
The Site Map displays the views available for the Inbox.
- Click Inbox Items List.
- In many cases, you can drill down on the Name hyperlink to see details about the work item.
