Fundamentals > Common Record Tasks > Creating RecordsYou can create records throughout the Siebel application using several methods, such as clicking a button or choosing an option from a menu. When you create a record, a new record appears, containing fields that you need to complete. The procedures in this section show how to create records using some of the commands available throughout the application. You can use whichever method works best for you, or whichever method is available. Some records contain read-only fields. Read-only fields are those in which you cannot enter data. You may not have user privileges that allow you to enter data in the read-only field, or the data may be automatically filled in by the system. NOTE: Not all users can create new records. Your ability to do so depends on the responsibilities given to you by your administrator. To create a record using the New button To create a record using the menu button
To create a record using the application-level menu
Related Topics |
| Fundamentals |
