Fundamentals > Common Record Tasks >
Freezing Columns in a List
Lists can contain many columns. You may find that you want to scroll to the right and view columns you cannot see without losing focus of the left-most columns. You can do this by freezing the desired left-most columns. An example of a list with frozen columns is shown in Figure 40.
Figure 40. Example of Columns Frozen in a List
To freeze columns in a list
- Select the list in which you want to freeze columns.
- Double-click the column header of the right-most column you want to freeze.
The frozen column headers now appear with a darker gray background. In addition, a dark gray vertical line appears separating the frozen columns from the unfrozen columns.
- Scroll to the right to view columns without losing focus of the frozen columns on the left.
To unfreeze columns
