Fundamentals > Setting User Preferences > Customizing Aspects of the Calendar > Turning On Alarms for All Calendar ActivitiesAlarms notify users of upcoming activities. You can specify that an alarm will be triggered for every calendar activity you create. To turn on default alarms for all calendar activities
NOTE: Clear the Default Alarm check box to turn off alarms for all activities. This will affect only activities you create after you clear the Default Alarm check box. |
| Fundamentals |
