Fundamentals > Setting User Preferences > Customizing Aspects of the Calendar >
Setting Up Default Alarm Lead Times
From the Calendar tab in the User Preferences screen, you can specify the time at which alarm notification takes place. For information about alarm system preferences, see the section on system preferences in Applications Administration Guide. To set the time when alarms appear
- From the application-level menu, choose Tools > User Preferences.
The User Preferences screen appears.
- On the link bar, click Calendar.
The Calendar form appears.
- In the Alarm Lead Time drop-down list, select a time between 5 and 120 minutes.
This is the time that all alarms will be triggered before an appointment or reminder.
