Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Fundamentals > Using the Calendar > Granting Access to Your CalendarWhen working with your team members, you may find that allowing them to see your activities or to add activities to your schedule is a good communication tool. To grant other people access to your calendar, add members to the Calendar Access List and give them view or update privileges. NOTE: Calendar sharing can result in the routing of large numbers of activities to mobile clients. To give others access to your calendar
Fundamentals |
