Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Fundamentals > Using the Calendar > Viewing Other Users' CalendarsYou can view only calendars to which you have been granted access. If you are a manager, you can view the calendars of your direct reports. To view another user's calendar
TIP: If your job often requires you to access another user's calendar, you may want to set up that user's calendar as your default calendar. This can be done from the User Preferences screen. For more information see Setting Up Another User's Calendar as Your Default Calendar. |
Fundamentals |
