Fundamentals > Using the Calendar > Setting AlarmsTo set an alarm for an activity, select the Alarm check box in an activity record on any screen that provides an Activities view or in the Calendar screen. NOTE: In order for alarms to work correctly, make sure that your computer's time zone setting is the same as the time zone set up in your user preferences. For more information about setting the time zone in user preferences, see Setting Time Zone Preferences. To turn on an alarm for a calendar activity
NOTE: You may want to have alarms go off for every calendar activity you create. You can set this up in your user preferences. For more information, see Turning On Alarms for All Calendar Activities. |
| Fundamentals |
