Fundamentals > Using the Calendar >
About Viewing Activities
Activities can appear in the Activities screen, in the Calendar, or in the To Do list. The place where an activity appears depends on the place where it is created. Table 15 explains how activities display.
Activities cannot appear in the Calendar and the To Do list at the same time.
Table 15. How Activities Are Displayed
If you create an activity here...
The activity automatically appears here...
Comments
Calendar screen
  • Calendar screen
  • Activities screen
If you do not specify a start time, the activity will only appear in the Activities screen, and not in the Calendar.
To Do list
  • To Do list
  • Activities screen
Activities screen
You must decide where you want to display the activity from the Display In drop-down list.
Your options are Calendar and Activities, To Do and Activities, or Activities Only.
If you choose Calendar and Activities, but do not assign a start time to the activity, the activity will not appear in your calendar.
Fundamentals
