Fundamentals > Using Selection Dialog Boxes > Launching Selection Dialog BoxesThere are two buttons, shown in Table 10, that launch selection dialog boxes: the single select button and the multiple select button. Single selection dialog boxes. Single selection dialog boxes allow you to add a maximum of one record to a field. In some cases you can create a new record from the single selection dialog box. Shuttle dialog boxes. Shuttle dialog boxes allow you to select a number of records and add them to a field. An example of a shuttle dialog box is shown in Figure 41. NOTE: To select records in selection dialog boxes you can double-click, press ENTER, or click OK. |
| Fundamentals |
