This chapter lists the application administration tasks that are specific to Siebel Hospitality. It includes the following topics: Use this chapter in combination with Applications Administration Guide, Product Administration Guide, and Pricing Administration Guide. Applications Administration Guide covers the setup tasks that are common to all Siebel Business Applications, such as using license keys, defining employees, and defining your company's structure. It also provides the information that you need to perform data administration and document administration tasks. Some tasks discussed in this chapter may replace the corresponding ones in the administration guide, whereas others may be additional tasks. Make sure you review Table 4 before following the procedures in Applications Administration Guide. This chapter assumes that you have already installed or completed the upgrade of Siebel Hospitality. and created the Siebel Administrator account that is used to perform the tasks described in this guide. For more information, see Siebel Installation Guide for the operating system you are using. If you are upgrading, see Upgrade Guide for the operating system you are using. |
| Siebel Hospitality Guide |
