Siebel Hospitality Guide > Working with Inventory > Time Shifting Event Functions and Room Blocks > Reviewing Time Shift Information at the Quote LevelUse the Quotes screen's Time Shift > Summary view to review details of both functions and room blocks that have been time shifted. This summary information is only based upon the active function spaces for a function, and does not take backup spaces into account. After time shifting functions it may also be useful to compare the revenue estimates for both the original and revised functions. This comparison can be made using the Quotes screen's Time Shift > Function Shift (Revenue) view. NOTE: Revenue is calculated at the time of the quote, based on the defined average value (see Setting Up Average Values and Function Types). However, if the revenue is to be calculated on the basis of the line items, then the user would select the Line Item Sum check box on the Quotes screen's Functions > Functions list. To review the time shift summary
To compare time shift revenue estimates
| Siebel Hospitality Guide |
