Siebel Hospitality Guide > Capturing Hospitality Opportunities > Selecting Properties for the Event Opportunity > Using the Property ScreenWhen you have narrowed the list of properties to properties in a specific area, you may use the Property screen to decide on the appropriate property or properties that you wish to use for the opportunity. This task is a step in Selecting Properties for the Event Opportunity. To find an appropriate property using the Property screen
| Siebel Hospitality Guide |
