Siebel Hospitality Guide > Setting Up Pricing and Property Pricing >
Defining Future Date Adjustments
Property administrators may define future date adjustments on the pricing of revenue categories. This means at a certain date in the future, the prices of all products in a certain category will increase by the defined percentage. This markup is rolled up into each individual quote when the quote price is calculated. This task is a step in Process of Setting Up Pricing and Property Pricing. To define a future date adjustment for a category
- Navigate to the Property Pricing Admin screen > Properties list.
- In the Properties list, select the property and click the link in the Property Name field.
- Click the Future Date Adjustment view tab.
- In the Future Date Adjustments list, create a new record.
- In the new record, complete the fields and save the record.
The following table describes some of the fields.
Name |
The name of the adjustment to be applied. |
Revenue Category |
The category to which the adjustment is to be applied. NOTE: You must select a category in this field or the adjustment will not be applied.
Revenue Parent Category |
This field is automatically populated when the Revenue Category field is completed. |
Start Date |
The date from which the future date adjustment is to be applied. |
Start Day |
This field is automatically populated when the Start Date field is completed. |
End Date |
The date on which the future date adjustment is no longer valid. |
End Day |
This field is automatically populated when the End Date field is completed. |
% Markup |
The percentage increase on all products in the category. |
