Siebel Hospitality Guide > Setting Up Properties >
Defining Airports and Booking Centers
Before a property record is created, an administrator defines airports and booking centers that are referenced in the property record. This task is a step in Process of Setting Up Properties. To define an airport and a booking center
- Navigate to the Guest Conveniences Administration screen > Guest Conveniences list view.
- In the Guest Conveniences list, create new records, and complete the fields for each record as follows:
- For an airport record, set the value in the Type field to Airport.
- For a booking center record, set the value in the Type field to Booking Center.
