Siebel Hospitality Guide > Setting Up Properties >
Process of Setting Up Properties
The following list shows the procedures that administrators typically perform to set up properties using Siebel Hospitality. Your company may follow a different process according to its business requirements. NOTE: This process is carried out as much as possible for nonparticipating properties. That is, all information available to you about NPPs should be used to build up the property's profile.
Administrator Procedures
To set up properties, perform the following procedures:
- Defining Airports and Booking Centers
- Creating Addresses for Properties
- Setting Up Guest Conveniences
- Adding Property Records
- Setting Up Nonparticipating Properties
- Defining Property Facilities and Room Service Attributes
- Defining Property Day Parts
- Updating the Property Team
- Defining the Property's Neighborhood Characteristics
- Defining the Property Profile
- Defining Property Policies
- Adding Property Floor Plans
- Creating Sell Notes for a Property
- Setting Up Special Dates for a Property
- Viewing the Property Calendar
- Setting Up Property Clusters
