Siebel Hospitality Guide > Setting Up Properties >
Defining Property Facilities and Room Service Attributes
After the property record is defined, the administrator can specify the facilities and room service attributes for the property. This task is a step in Process of Setting Up Properties. To define property facilities
- Navigate to the Property Administration screen > Properties list view.
- In the Properties list, query for and select the required property.
- Click the link in the Property name field, and then click the Facilities view tab.
- In the Facilities form, select the check boxes for each amenity at the facility.
To define room services
- Navigate to the Property Administration screen Properties list view.
- Click the link in the Property Name field, and then click the Room Services view tab.
- In the Room Services form, select the check boxes for each room service amenity at the property.
