Siebel Hospitality Guide > Setting Up Properties >
Defining Property Day Parts
After the property record is defined, an administrator sets up the property's day parts, segmenting the operational day into periods of time. This task is a step in Process of Setting Up Properties. To set up day parts
- Navigate to the Property Administration screen > Properties list view.
- In the Properties list, query for and select the required property.
- Click the link in the Property Name field, and then click the Day Parts view tab.
- In the Day Parts list, create new records, complete the fields for each record, and save the records.
The following table describes some of the fields.
Day Part Name |
The name of the day part. For example, Morning. |
Start Time |
The start time of the day part. For example, 6 A.M. |
End Time |
The time that the day part ends. For example, 12 P.M. |
Include in Full Day Threshold |
This check box is used for Full Day discounts. Select it if the day part is to be a part of the Full Day Threshold.
- If this check box is selected, then any functions may not qualify for a full day discount unless the function touches this day part.
- If this check box is not selected, then functions may qualify for a full day discount without touching this day part.
Comments |
Add any relevant comments about the day part. |
NOTE: Day parts can span over two different days. For example, a day part might run from 10 P.M. until 3 A.M. However, day parts must only span one 24-hour time period.
To validate day parts
- In the properties list, select the required property, and click the link in the Property Name field.
- Click the Day Parts view tab.
- Select the first day part in the list, and click Validate.
- If there are any gaps or overlaps between the day parts, a dialog box appears prompting you to recheck the day-part definitions.
- If the day parts are validated, then the last day part in the list is selected after the validation.
