Siebel Hospitality Guide > Managing Property-Specific Event Quotes > Overriding Multiple Event QuotesChanges can be made across all the event quotes associated with a specific opportunity. The user performs this task by updating the opportunity record and overriding all the quotes associated with the opportunity. If a particular quote should not be overridden, the Do Not Override flag is set for the opportunity quote record. Selecting the check box flag indicates the quote is to be ignored and not be overridden by the new quote created from the opportunity. This task is a step in Process of Managing Property-Specific Event Quotes. To modify multiple quotes using the Opportunities Quotes view
| Siebel Hospitality Guide |
