Siebel Hospitality Guide > Managing Property-Specific Event Quotes > Generating Quotes from OpportunitiesProperty-specific quotes can be generated from ordinary opportunities from the Opportunity > Properties view. Perform the following procedure to generate a property-specific quote. This task is a step in Process of Managing Property-Specific Event Quotes. To create a quote for an event property
NOTE: You can also generate multiple quotes by selecting multiple properties and clicking Create Quote. If you use this method, the quote for the primary property is created first, and then all other quotes are created. Related Topic |
| Siebel Hospitality Guide |
