Implementing Siebel Business Applications on DB2 UDB for z/OS > Installing the Siebel Schema on the DB2 Host >
Process of Installing the Siebel Schema
After installing the Database Server software at midtier, you must install the Siebel Schema on the DB2 host using the Database Server Configuration utility. To install the Siebel Schema on the DB2 host, perform the following tasks:
- Review information about installing the tables, indexes, and seed data, using either the standard or custom option. See About Installing the Siebel Schema.
- Install the Siebel Schema:
- Review the log files for any errors. See About Reviewing the Log Files for Windows or About Reviewing the Log Files for UNIX.
