Siebel Order Management Guide > Workflow and Method Reference for Order Management Interface > Order Management Interface Workflow Reference >
ISS Post Approval Workflow (Quote) Workflow
ISS Post Approval Workflow (Quote) workflow, shown in Figure 26, checks whether any additional approvals are needed.
It is triggered when a user approves an Quote to see if additional approvals are needed.
Figure 26. ISS Post Approval Workflow (Quote) Workflow
Click for full size image
Workflow Description. This workflow does the following:
Calls the SetApprovalDecision method. This will set the status of the current approval item and check to see if additional approval is needed.
Process Properties
Name
Business Object
Data Type
Comments
ActionLIC
Quote
String
The Language Independent Code for the Action Field
Approval Level Name
Quote
String
The name of the Approval Level that is defined in the Approval Administration screen.
Error Code
Quote
String
The Error Code that is returned if an error occurs.
Error Message
Quote
String
The Error Message that is returned if an error occurs.
InboxItemId
Quote
String
The Row ID of the current Universal Inbox Item.
InboxTypeName
Quote
String
The Universal Inbox Type.
Object Id
Quote
String
Obsolete.
ObjectId
Quote
String
The Row ID of the current object.
OwnerInfoId
Quote
String
The Row ID of the approver.
Process Instance Id
Quote
String
The Row ID of the current workflow process.
Returned Status
Quote
String
The Status of the Approval Item.
SendEmail
Quote
String
Variable to determine if email is sent to the person who needs to approve the current item.
SeqNum
Quote
String
The Sequence Number for the current approval level.
Siebel Operation Object Id
Quote
String
The Row ID of the Siebel Operation Object.
StageId
Quote
String
The Row ID of the current Approval Stage.
Siebel Order Management Guide Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices.
