Siebel Order Management Guide > Workflow and Method Reference for Order Management Interface > Order Management Interface Workflow Reference >
ISS Post Approval Workflow (Order) Workflow
ISS Post Approval Workflow (Order) workflow, shown in Figure 27, checks whether any additional approvals are needed.
It is triggered when a user approves an Order to see if additional approvals are needed.
Figure 27. ISS Post Approval Workflow (Order) Workflow
Click for full size image
Workflow Description. This workflow does the following:
Calls the SetApprovalDecision method of the ISS Approval Bus Service Business Service. This will set the status of the current approval item and check to see if additional approval is needed.
Process Properties
Name
Business Object
Data Type
Comments
ActionLIC
Order Entry
String
The Language Independent Code for the Action Field
Approval Level Name
Order Entry
String
The name of the Approval Level that is defined in the Approval Administration screen.
Error Code
Order Entry
String
The Error Code that is returned if an error occurs.
Error Message
Order Entry
String
The Error Message that is returned if an error occurs.
InboxItemId
Order Entry
String
The Row ID of the current Universal Inbox Item.
InboxTypeName
Order Entry
String
The Universal Inbox Type.
Object Id
Order Entry
String
Obsolete.
ObjectId
Order Entry
String
The Row ID of the current object.
OwnerInfoId
Order Entry
String
The Row ID of the approver.
Process Instance Id
Order Entry
String
The Row ID of the current workflow process.
Returned Status
Order Entry
String
The Status of the Approval Item.
SendEmail
Order Entry
String
Variable to determine if email is sent to the person who needs to approve the current item.
SeqNum
Order Entry
String
The Sequence Number for the current approval level.
Siebel Operation Object Id
Order Entry
String
The Row ID of the Siebel Operation Object.
StageId
Order Entry
String
The Row ID of the current Approval Stage.
Siebel Order Management Guide Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices.
