Siebel Order Management Guide > Setting Up Product Recommendations > Product Recommendation Technical Reference > ExecuteUpsell Business Service MethodThis method is part of Product UpSell CrossSell Service. UsageExecuteUpsell Business Service method is triggered when the user clicks Accept for an upsell recommendation. It changes the product on the current line item to the recommended product. Then, depending whether the current product and recommended product are simple, bundle, or customizable products, it performs the actions described in Table 21. When one compound product is changed to another, the user must launch Configurator to generate missing components and attributes, to delete disallowed components and attributes, and to ensure a valid configuration. As much of the original configuration as possible is retained. InputIf the business service is invoked from UMS, then Related Product Id is a required property under the child property set Payload. If the business service is invoked from anywhere else, Related Product Id is the only required property. Output |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
