Siebel Partner Relationship Management Administration Guide > Partner Programs Administration > Setting Up Partner Programs > Setting Up a Partner Program ApplicationA partner program application is a form that the partner completes on the PRM Portal when applying to join a partner program. The brand owner's internal users can attach SmartScripts to a partner program application. Each program can have one SmartScript initial application and one Smartscript renewal application. The actual design and administration of SmartScripts are performed in the SmartScript Administration screen. For more information on SmartScripts, see Siebel SmartScript Administration Guide. Alternatively, the brand owner can attach URLs for the .asp or .jsp pages that will render the initial and renewal applications. NOTE: For any given partner program application, you can specify either SmartScript applications or external applications, but not both. This task is a step in Setting Up Partner Programs. To set up a partner program application (brand owner)
| Siebel Partner Relationship Management Administration Guide |
