Siebel Partner Relationship Management Administration Guide > Working with New Partners > Enrolling New Partner Companies > Registering the Partner CompanyFor any method you choose to use to add a partner company record, you must register the partner company. Use the following procedure to register a partner company. To register the partner company
About Placing the Partner Company in the Organization HierarchySiebel applications let you divide your business into organizations, which control visibility to data. For example, when users choose All Contacts, they display the contacts in their own organization. While setting up Siebel PRM, your company's partner operations manager may have created a hierarchical organizational structure to organize your partner companies. For example, there may be a hierarchy that organizes partner companies based on the product they specialize in or the industry in which they work. When you register a new company, you must place it in the organization hierarchy by choosing its parent organization. For example, if your hierarchy is based on industry, you must place the new partner organization under the organization for the appropriate industry. You can also create a hierarchical structure with multiple organizations for the partner company itself. For example, if you assign opportunities to different regional divisions of a partner company, you can create an organization that represents the entire partner company and organizations under it in the hierarchy that represent its regional divisions. Then, you can assign opportunities to organizations representing the regional divisions, and only the division you assigned the opportunity to will be able to see it. For more information about setting up the organization hierarchy in Siebel PRM, see Setting Up Siebel PRM. For more information about using organizations to control visibility to data, see Security Guide for Siebel Business Applications. About Specifying the Partner Manager for a Partner CompanyIf you are using market development funds (MDFs), you need to specify an employee in the partner manager field, so that fund requests are routed properly for approval. The employee selected in the partner manager field is the first to approve an MDF request. If you are not using MDFs, you do not need to use the Partner Manager field. You can enter a sales team instead. You may want to use the Partner Manager field as well as the Sales Team field to indicate that one person has primary responsibility for the partner. In any event, the employee selected in the Partner Manager field must also be on the sales team to have visibility to the record in My Partners view. The partner's record is displayed in My Partners view for members of the account team. NOTE: The employee selected in the Partner Manager field does not automatically have visibility to the Partner Record in the My Partners view. The Sales Team field determines who has visibility to the partner record in the My Partners view. You can display the record in the Approved Partner list and, in the More Info form, add employees responsible for the partner to the sales team. Registering the Partner CompanySelect the Partner record and click Register to place the partner in the organization hierarchy and specify the Partner Manager field. NOTE: After you register the partner company, you cannot delete the partner organization. Be sure you want to create a new organization before clicking Register. To register the partner company
After enrolling and registering the new partner, add the company identifier to start processing user applications from the Administration - Partner screen > Partner User Applications view. |
| Siebel Partner Relationship Management Administration Guide |
