Pricing Administration Guide > Creating Attribute Adjustments > Using Variable Maps in Attribute AdjustmentsYou use variable maps to map the dimensions of attribute adjustments to fields in Siebel business objects. For information about variable maps, see Siebel Order Management Infrastructure Guide. There are three types of variable maps:
For attribute pricing, you need only the standard variable maps that are provided with the product. The Siebel application provides standard variable maps for all of these variable map types. The variable maps that attribute adjustments use are declared in the Systems Preferences view as shown in Table 7. While setting up an Attribute Adjustment table, the pricing administrators can associate the variable maps shown in Table 7 by clicking the Create Result Dimensions button. The three variable maps are created for the attribute adjustment in the Attribute Adjustments > Variable Maps view along with the two pricing results dimensions, Adjustment Type and Adjustment Amount. The system preferences, as shown in Table 7, are read and a record is inserted for each variable map type in the System Preferences view. CAUTION: If the system preference value is either empty, nonexistent, or invalid, then that variable map record is not created. No error message appears. If a user has already created the variable map records, then the application does not overwrite them. The use of variable maps for attribute adjustments is transparent to the pricing administrator. The Variable Maps view tab does not appear in the user interface, but you can still access it using the Site Map to navigate to Administration - Pricing > Attribute Adjustments > Variable Map. You can set up variable maps in either of two ways. To set up variable maps for pricing adjustments by modifying system preferences
To set up variable maps for pricing adjustments by overwriting the variable maps in the Variable Map view
The first approach is a global level change, and any new attribute adjustment table created after the server is restarted uses the new variable maps. The second approach is a local level change, and only the attribute adjustment that is modified uses the new variable maps. |
| Pricing Administration Guide |
