Pricing Administration Guide > Pricing in the Run-Time Application > Pricing Waterfalls > Configuring Pricing WaterfallsTo configure the pricing waterfall, you modify the pricing procedure used to display the waterfall. For more information about this pricing procedure and the PSP waterfall business service that it calls, see Siebel Pricer Technical Reference. For more information about working with pricing procedures and messages, see Siebel Order Management Infrastructure Guide. This section gives you general instructions about some common ways of configuring pricing waterfalls. Adding a New Pricing WaterfallTo create a new pricing waterfall, follow these instructions:
Adding a New Field to the Pricing WaterfallYou can add a new field to the information in each row of a waterfall. For example, you might want each row to include the approval level that was needed to give the discount in that row. To add a new field to the pricing waterfall, follow these instructions:
Saving Pricing Waterfall OutputIn general, the pricing waterfall is generated on demand when the user clicks the Show Details button, instead of being stored in the database. When the record is repriced, the waterfall displays. You can save the waterfall to the database at any time by selecting a line item, and then clicking the Save Waterfall button in the Line Items list of a quote, order, or agreement. You can also configure the product to invoke the SyncToDB method of the PSP waterfall business service to save the waterfall for an entire document. However, writing the waterfall to the database can slow performance, so do it only if it is necessary. For example, you might save waterfalls to analyze the discounts you give customers, or to calculate incentive compensation. Configuration for WaterfallsYou must configure the Siebel application to create a user interface for viewing a stored waterfall. For more information about configuring Siebel applications, see Using Siebel Tools. For more information about configuring Siebel Pricer, see Siebel Order Management Infrastructure Guide. |
| Pricing Administration Guide |
