Pricing Administration Guide > Creating Pricing Reports >
Running Reports
You can run all the reports described in this chapter in the same way. To run the Price Lists report
- Navigate to the screen and view from which you access the report, as specified in the report's description.
- In the application-level menu, click the Reports icon and select the appropriate report.
- In the Reports dialog box, select the report name from the drop-down menu and click Run Now.
The selected report appears in the Siebel Report Viewer.
- You can print a copy of the report by clicking the printer icon.
