Product Administration Guide > Product Attributes with Business Component Domains > About the UI Properties for Attributes with Business Component DomainsYou can define an attribute that has values the user can select from a pick applet. The pick applet displays records from a specified business component. When the user selects a record, a specified field in the record displays in the selection page as the value of the attribute. Several predefined UI properties are provided to associate the attribute with a pick applet and picklist. Defining these UI properties on the attribute replaces the Siebel Tools procedures for configuring the originating business component when defining a pick applet. You define these UI properties on the attribute that you have set up to display a select button in the selection pages. These UI properties associate the attribute with a pick applet and a picklist and are shown in Table 6. The PickMap value is an XML tag that has the following format: <PickMap Field="AttributeName" PickField="BusCompFieldname" Constrain="Y/N" BusObj="BusObjName" /> For UI properties with Constrain="Y", specifies the business component field name or attribute name to be used as a filter for the records displayed in the pick applet. The format for specifying a business component is For example, to constrain the records displayed in the pick applet to those having the current record's Opportunity name in the Quotes view, (Quote business component), you would enter |
| Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
