Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
GetFieldValues Method
This method retrieves field values for a product that exists in the complex product. Input Arguments
- ObjId. The unique identifier of the complex object root (for example, Quote ID).
- RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
- (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
- Path - the path to the item.
Output Arguments
The output property set returned will have the field names as properties, as follows: < Field="value" Field="value" ... Field="value"/>
