Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
GetInstance Method
This method gets the loaded instance as a property set. It returns the full structure of products and attributes. Input Arguments
- ObjId. The unique identifier of the complex object root.
- RootId. The unique identifier of the complex object root.
- (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Output Arguments
The entire property set output is the complex object instance.
