Version |
The version of the form. |
1 |
Inactive |
Selecting this check box makes the form inactive |
Integration Object |
The integration object created or modified for forms integration. |
Contact |
Request |
Allows you to request files from the server. When a check mark appears in this field, the document is retrieved during the next synchronization session. This field only applies if you use Siebel Remote. |
Update |
A check mark in this field indicates that you want your copy of the file to be updated automatically each time the original file is updated. |
Business Object |
Automatically completed when you choose the integration object |
Contact |
File Name |
The name of the PDF file. Navigate to the file on the network. |
Sample_Contact.pdf |
File Type |
PDF |
Adobe's Portable Document File format. The file type value is automatically populated when you select the file. |
Type |
Indicates the document type in which the form is generated. PDF is the only supported option at this time. |
PDF |
Attachment Business Component |
This field determines where the generated form is attached to the record. |
Contact Attachment |
Forms Adapter |
Choose Forms Integration PDF Adapter Service in most cases. Debug Forms Integration PDF Adapter can be used to troubleshoot issues with the Adobe integration. |
Forms Integration PDF Adapter Service. |
File Adapter |
Choose Forms Integration File Adapter Service |
Attachment View |
The Attachment View determines to which view the user is navigated after the form is generated. |
Contact Attachment view |
Search Specification |
Allows the administrator to select certain information from the integration object's child business component |
To include information from a Contact's Account only if the account is Active, the value in the Search Specification field should be "[Contact_Account.Account Status] = 'Active' " where the Integration Component Name = Contact_Account. |
