Siebel Public Sector Guide > Setting Up and Using Adobe Forms Integration > Generating a Form Using a Siebel Record (End User)Users can generate a PDF document that is automatically populated with data from a Siebel record such as a contact. The PDF file is stored in the Attachments view associated with the record. This task is a step in Process of Setting Up Adobe Forms Integration. To generate a form with data from a record
Generation of Forms for Multiple RecordsThe procedure for generation of forms from multiple records, such as contacts, is performed the same way as for a single record. When generating multiple forms, for example, for a Citizenship Ceremony, consider the complexity of the form and the number to be generated, and perform the task in batches. For example, if the form is relatively simple, you can typically generate 200 forms at one time without impacting performance. If the form is complex, generate the forms in batches no greater than 100 forms at one time. |
| Siebel Public Sector Guide |
