| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel Public Sector Guide > Setting Up and Using Adobe Forms Integration > Preparing for Adobe Form Integration SetupYou must perform the following preparatory steps before you can set up and use Adobe forms integration with your Siebel application. After you have verified that the tasks are complete, you can begin the forms integration tasks. For more information on software version requirements for Adobe form integration, see System Requirements and Supported Platforms on Siebel SupportWeb. This definitive list of system requirements and supported third-party products is located on SupportWeb at Product Documentation > System Requirements and Supported Platforms & Miscellaneous Documentation. This task is a step in Process of Setting Up Adobe Forms Integration. To prepare for Adobe forms integration setup
| Siebel Public Sector Guide |
