Siebel Public Sector Guide > Setting Up and Using Adobe Forms Integration >
Creating the Web Service for Adobe Forms Integration
Using Siebel Tools, perform the steps in the following procedure to create the Web Service for Adobe forms integration. For more information, see Using Siebel Tools. This task is a step in Process of Setting Up Adobe Forms Integration. To create the Web Service
- Launch Siebel Tools and log in as the administrator.
- From the application level menu, choose File > New Object, and from the New Objects Wizard dialog box click the EAI tab and choose Web Service.
- From the WSDL Import Wizard wizard screen, perform the following tasks:
- Select a project.
For example, select Contact as the project.
- Specify the WSDL document file from which to import.
The WSDL document file is provided by Adobe.
After the WSDL document file is selected, the following field values are automatically populated. Do not change the default values.
Run-time data file: <path>\SiebelIntegration.xml
Log file: <path>\SiebelIntegration.log
- Click Next, and then click Finish.
- Compile the project using Siebel Tools.
